Ill chime in, I didnt read all the comments so this may have been addressed, if something is binding or the box is over tightened, it will give a sensation of being loose, one question to answer does the car have memory steer? Do you physically have to move the steering wheel to get the car to come back out of a light turn? When you make small corrections while driving, does the car keep going in that direction without input to the wheel??Let's be realistic here. Steven has already replaced the rag joint with no improvement and reported it all moves together. Throwing another upgrade at is not the problem. He also claimed 2 other g bodies drive normal. His is going stripe to stripe. This kind of slop can't be hard to find.
Steve. What are the alignment specs? If you stand outside the driver's window and saw the wheel left and right. Does the tire move right away? These cars will not feel like a new Corvette but stripe to stripe. Even with a worn front end, they are not that bad. Push the rear of the car sideways, how much does it move? Not counting the tire sidewall?
That was one of the reasons I had our mechanic check the alignment. I figured maybe there wasn't enough caster in it because It does not return to center on it's own,Ill chime in, I didnt read all the comments so this may have been addressed, if something is binding or the box is over tightened, it will give a sensation of being loose, one question to answer does the car have memory steer? Do you physically have to move the steering wheel to get the car to come back out of a light turn? When you make small corrections while driving, does the car keep going in that direction without input to the wheel??
I am an auto tech in a Ford dealership for over 30 years, in my opinion something is tight, gear boxes are a finicky b*tch when it comes to gear preload, I got a quick ratio 800 series box from a asphalt racer and I had to loosen the mesh as they or whoever had it to tight, which is why I think they got rid of it.That was one of the reasons I had our mechanic check the alignment. I figured maybe there wasn't enough caster in it because It does not return to center on it's own,
I agree, but some of those rack/pinion steering systems are 20+ years old themselves. Hardly "modern" IMO. Still, better than the stock G-body styles.You have to remember, these cars will NOT feel like a modern vehicle with rack and pinion steering. Ever.
