I'd be removing the engine to give it back to the engine builder so he can find out where he went wrong..
pontiacgp said:I'd be removing the engine to give it back to the engine builder so he can find out where he went wrong..
anakputa said:Get some engine oil dye and see where the leak is coming from.. probably a loose or missing galley up by the cam. Put the dye in run a few seconds then drop the trans..hopefully its not a cracked block..
pontiacgp said:I wasn't saying anything the engine builder but it's been a few weeks that you've be trying to find the leak. It's a fresh installed engine so it's only a couple of hours to get it out..
Bonnewagon said:Pain in the *ss or not, I'd be spinning the oil pump with a tool and eyeballing everything. Or maybe get your builder friend to do it, he should be familiar with the operation.
pontiacgp said:did you find the leak yet?...
