Would a blown head gasket cause a car to stall on have a lot of trouble starting back up? Or is that another issues all together?
People keep asking me that but I have a terrible sense of smell. I'm always working alone so I have no one to ask.
Does it smell sweet people ask? Well it definitely doesn't smell like candy is shooting out if my exhaust lol if I had to put money on thiugh I would say it does smell a little sweet.. doesn't quite smell like normal gasses fumes at least
if it's coolant that's burning it has a distinctive sweet smell. What transmission do you have, I have seen the transmission fluid get sucked into the carb from a th350, transmission fluid will also give off white smoke
pull the plugs to see if they are white and take a look at the dipstick to see if there is coolant in the oil and under the oil filler cap to see if there is any residue from coolant and oil mixing. I don't see how the head gaskets blew when you really have no miles on the engine and you have not mentioned it has ever seriously overheated.
Just look in the radiator and see if your coolant is low
a few things,you mention you have a 200-4r in the car so im assuming it once had the computer controlled setup via the electronic quadrajet and distributor.did you reuse the original distributor?if you took it off the computer yet are still using it it will run like crap possibly to the point of stalling out if the internals got too heat soaked and ruined but i think in that case you would smell the lovely sulphury bad egg smell.the 200-4r requires correct tv geometry to not basically eat itself,did you get the tv cable bracket for your holley?it doesnt take long at all and would make it stall pretty quickly id imagine once detrimental damage has been done.also on that note do you have the converter lock up on a switch or not used at all?if its on a switch and engaged i know coming to a stop and forgetting to turn it off makes it buck like a mule before stalling out.as for the smoke if it was burning coolant youd most definitely smell it through the exhaust its not candy like but more of a sickly sweet smell,you can pull all the plugs and bump it over to see if any if caught in the cylinders but if it were to the point of smelling it through the exhaust you should be able to see milkshake on the dipstick or in the radiator depending on where the head gasket blew(oil in the coolant or coolant in the oil)
