Car shakes & squeals when turning wheels in place?
joesregalproject said:
pontiacgp said:
did you make sure you got all of the air out of the system?
No I haven't, that would explain the squealing but not the shaking. I might as well give it a try, to eliminate one more thing.
air in the system could make it shudder if that's what you mean by shaking. You should lift the front end off the ground and cycle the wheel L2L several times and check for air in the reservoir.
That's what I mean... The entire car shudders pretty bad.
there is alot of pressure in the line to the steering box, you get some air in it and you will feel it
