Avoid getting reman carbs, they are often rebuilt to generic specs instead of factory specs, and they often are cob together from mis-matching Qjets airhorns, bodies, and base plates. That is why many reman carbs never work right and sometiomes can't be restored back to OEM specs. Reman and rebuild are two very different processes. It is much better to rebuild your original carb back to factory specs using a high quality rebuild kit that has the proper spec parts. Many cheap rebuild kits are also generic specs instead of factory specs. The cheap parts also don't stand up to E10. In most cases you can rebush your base plate with homemade teflon bushings. If it is too worn for that, there are metal rebushing kits with special piloted drill bits. Lastly you can also take yor orignal carb to a good carb rebuilding shop who can restore the carb, rebush it, and just about anything else. You will always need to fine tune the carb after it is rebolted to your engine after it is rebuilt.
