carb ?
azmalibuwagon said:
damn dust storms.
You can test the choke pull off - disconnect the vacuum hose from the front of it, push the plunger in, then cover the air hole that you just uncovered when you pulled off the hose. Let go of the plunger. It should stay in until you remove your finger.
You can disconnect the choke. The car will probably run crappy for a few minutes while it warms up, but then run fine; I've had mine off all summer.
Remove that screw right in the very top center of your picture and pop it loose. The screw is short so make sure you don't loose it. Try it and see if anything changes. If not, reconnect the choke.
I dont mind having it run rough for a few minutes, I usually let it idle for 10-15 minutes before I take off to work in the morning. Im going to try taking it off 🙂 thanks for the advice.
kuruption109 said:
hey im looking at ur fuel line inlet it sits to the side and not at a angle .. u cud have got a carb from the junk yard off of one of them 4 door cutlass
Naw those had the inlet going straight remember? I even said thats why I cant use them. I called around and I guess only 82-83 models have my style carb.
azmalibuwagon said:
damn dust storms.
Do mine showing me exactly wich screw your talking about? I dont want to take the wrong one out. A pic would really help.
kuruption109 said:
o yea i got ur 5 packs of spicey ketchup
LOL only 5!
Just remove the choke flap all together :idea:
Well, let's see if I can upload a pic.
To disconnect the choke, remove the screw in the red rectangle and pull off the fitting that is right behind it. The choke then will just stay open.
If you need to remove the choke pull-off, take out the two screws in the yellow rectangle
v2vera said:
azmalibuwagon said:
damn dust storms.
The screw is the one at the end of the choke shaft - it's a slot screw that retains the arm to the choke shaft.
I wouldn't do it this way, though. IMHO it's better to back off the choke thermostat so it doesn't close at all. To do this, you'll need to drill out the three rivets that retain the choke housing. In the old days, these were screws, but for emissions purposes they made these rivets later on.
Once you drill out the rivets completely you'll be able to remove the choke thermostat. This will allow the choke to fall open. You can drive this way in warm weather, but you'll have to pump it a bit to start.
