huh thats weird maybe all they have is obd2 scanners now but the way cannon mutant posted a page ago is very easy,just locate the aldl connector and insert a paperclip between the a and be terminals then put your ignition into the run position,dont start the car.then observe the check engine light,you'll have a series of pulses of a long pulse the a series of short pulses (i.e. flash....flash,flash for instance meaning code 12 which points to no distributor signal,indicative of ignition being on but engine not running)
http://performanceolds307.tripod.com/id2.html
this link gives most all the trouble codes you will find and their associated meanings
