Would it work with my setup and if not what all would I need ?That's a Carter AFB. It's a square bore type.
Send it to Everyday, and make sure you give engine specifics. Edelbrock carbs aren't worth the box they come in.
The design dates to the late 50's & Gm asked the designers to do better & the Q Jet was borne.
They seem to run especially bad on the Olds V8. Nearly every poor running car had an Edelbrock carb on Classic Olds. Some spent many hours no avail.I never had an AFB style carb run worth a flip on an Olds. I ended up going to a Holley spreadbore or back to a Qjet. The plus to a Carter/E-brock is the ability to change metering rods rather quickly, and they do pretty much stay where they're set, but they also had a lot of extra flashing where it didn't need to be and other machining problems. At least the ones I had back in the late 70s/early 80s did. I did trade one of my Holleys for a Thermo-quad once, thinking the spreadbore design would be better without having to use an adapter. It ran ok, but not great, and still had to fiddle with it to get it there. It felt like bolting on a Holley sideways though. Those things were huge side to side.
My dad had a Chevy pickup truck back in the 70s that had a CARTER Quadrajet on it. Yup, for a brief time, Carter supplied GM with Qjets. It ran pretty good. I used it practicing for my driver's license. I also learned how to do long posi-traction burnouts with that truck... 🙂
