Carrier Question
I'm going to lose my 2.41s in favor of 3.23s- are the 7.5s like the 8.2/8.5 where you need a different carrier once you go over a certain gear ratio? I vaguely recall 3.08 being a break point....
6,836
6,748
Yep. 3.08 and numerically lower are series 2. 3.23 on up are series 3. They do make series 3 numbered gears that fit in the 7.5 housing with a series 2 carrier. I think its the ring gears that are thicker on series 3... maybe other differences.
DRIVEN
8,079
14,556
*CENSORED*
You'll need a 3-series. Up to and including 3.08 is 2-series. 3.23 and up is 3-series.
20,397
You can use the 2 series carrier for the 3.23 gears by adding a spacer..
https://www.speedwaymotors.com/7-1-2-Inch-GM-Ring-Gear-Spacer-with-Bolts,7534.html
DRIVEN
8,079
14,556
*CENSORED*
I got a 2-series from a 87(?) Camaro with 26 splines and used a spacer for 3.42s. Worked okay.
So, if I do in fact get a 3 series carrier, it seems that the only spider gear kit in 26 spline I can find is made by SVL. The product description says they're backed by Dana. Never heard of them..... Yukon only makes them for 28 spline, according to their website.
20,397
SVL are gears made in India and use the Dana name to make people think they are quality gears.
check these guys, some of their parts are OEM stock
https://eastcoastgearsupply.com/i-1828247-gm-7-5-spider-gear-kit-26-spline.html
