malibu80 said:I would also agree that the belts need replacing. If you live in Vancouver, BC, I would recommend Main Electronics. They're are Main and 29th. Take the belts with you. They'll match something up for you. Belts are specific to model and make. Another area that needs attention is the rubber wheel that pinches up against the shaft. It needs to be cleans with a Q-tip drenched in alcohol. The wheel gets glazed and becomes slippery. Sure tale sign is that the tape gets eaten or the speed is varied. While your at it, check the condition of the cassette head. Run your finger nail across it. If you feel a groove in it then the head is worn out. The tape is pulled across the head and eventually wears out.
Ok I Can check all of this, I dont live in vancouver i live in Ontario In Milton 🙂 Well i just took a crappy cassette player at my home apart and got 2 belts out of them, ill see if they match this delco one
