CENTER IN CENTER OUT
19,992
Anyone running center in center out with 2 1/4 or 2 1/2 inch true dual exhaust?
Have a pic?
How does it sit?
Tight to the floor?
Thanks!!
19,992
No one?!?!?!?!!?!?
spidereyes455
788
1,644
Northeastern PA
The only instance that comes to mind is the factory vin 9 exhaust used on H/O and 442's. Every other install I've seen used either offset/offset or offset /center mufflers.
Gonzo1970
898
1,302
Not yet... wife is impeding my dual exhaust progress with needless spending... :D
-Gonz
9,618
12,701
This was the mock up phase of my 86' Regal installing a new Walker cat back for a stock 442 which is 2.25' pipes, it sits higher bolted up and will eventually be a true dual exhaust if I don't use my Jegs kit.
19,992
I can get a new set of Borla pro xs for free
But they are center center
I have always used offset offset
The factory 2 into 1 into 2 uses center center
I will be running true dual no x/h pipe
I dont want to take them if I cant use them
spidereyes455
788
1,644
Northeastern PA
If you're using a prefabricated kit they probably wont fit most kits are designed around center/offset or offset/offset mufflers. If you're having a muffler shop custom bend a set then the pipes can be made to fit almost anything.
9,618
12,701
Is the VIN 9 duals for the Oldsmobiles still available?
I bought mine a couple years ago and had to buy from multiple vendors just to piece it together because most of it was being discontinued.
