I don't remember what Scott used, but we used a set of fans from a 4th gen F-Body. It required very minimal trimming of the fan assembly and fabbing some little sheet metal mounting strips. Same radiator so it should work well in a G-Body. I know the Intrepid fan setup is popular but I believe it is a single, two speed fan. I like the 4th gen F-Body setup since it has two fans, which pairs well with the GM PCM. We used a Painless fan relay kit, which was admittedly overpriced but convenient.What about the electric fans. what does everyone run or plan to run?
Check out post No. 73 for pics....
https://gbodyforum.com/threads/seans-78-camaro-z28.63930/page-8
That's with the Griffin radiator but we are using the same setup, slightly modified with the Champion radiator. The Champion radiator fits better. We have the fan assembly in upside down, relative to how it would be in a 4th gen Camaro to clear the 2nd gen Camaro's steering gearbox.
Edit: The 4th gen F-Body fan assembly would work well with the Cutlass radiator top plate.
