Mr. Sony is correct.
Essentially, the governor affects only low vacuum (WOT) shift points, while the modulator influences light to mid-throttle shift points.
Make sure your modulator is plumbed directly to manifold vacuum, not ported vacuum. Is the trans dead stock or has it had any mods, such as a shift kit or raised line pressure? If so, you may have to reverse the mods. I'd try the adjustable modulator first, as it's easy to change.
Bill
Bill
