pontiacgp said:I had a proform distributor and I wouldn't suggest anyone to make the same mistake...
St.Pete_MC said:Yeah when I bought it, the guy threw in the orginal gear that was on the dist. to begin with.
Phoenyx said:What cam are you gonna use. Because the material the cam is made out of determines what gear you need. I had a buddy smooth out a distributer gear because of this. To bad too, it was a fresh 383 sbc. He just changed the gear and did an oil change. But I think the damage was done. He only got one season (Canada) and the motor was done. So you should make sure on what gear you need.
custom442 said:pontiacgp said:I had a proform distributor and I wouldn't suggest anyone to make the same mistake...
I took apart the coil and there's a ground hangin out inside the coil box. This might have been the problem with the proform distributor. I'll fix the ground and see how it does.
