changing manual regulators to power
sslover85
34
49
Ok you all my car is an 85 SS with power everything. I'm converting my car to 87-88 style and have 87 doors but they are manual. How hard is it to put my 85 window guts into the 87 doors???
it should be as simple as pop riveting it in, as far as wiring it up, run your wires to the fuse panel. look it up on youtube, might get lucky.
for the wiring check behind the kick panels, you may have the harness already there to plug the door harness into. Do you have power locks in your doors?
yes I have all the power stuff on the car now but my replacement doors are manual.
then you can just transfer the power regulator to the replacement doors...I'd do one at a time so you can check the old door for the set up if you get confused..I said if for you, for me it's when.. :mrgreen:
