Check engine code 1… 2.
1983MonteLS
25
4
Can anyone describe the 1 and 2 quick CEL code is, what are the symptoms and what are the fixes? Google has some really bad info on this, it amazes me.
I’ll post a video
79 USA 1
1,065
2,039
Cheektowaga, New York
More or less a check code. Not a problem code.
Will start with the 1...2 flash, then your error codes If any then back to the 1...2.
Code 12No distributor reference pulse (diagnostic test active)
Hope this helps.
8,195
17,597
If you get a 12 code while driving, it's a problem. But during the diagnostic tests, you expect it. This means it is in active diagnostic mode and communicating with the ECM. If this is the only flashing you get, then that's good. Means no driveability codes. If it does, listen to what 79 USA 1 is telling you.
1983MonteLS
25
4
I’m guessing the new carb may be throwing different signals and readings to the ECM - perhaps relearning? I know their not the new smart cars, but do they relearn new computerized parts added?
8,195
17,597
If you're not getting any other codes, then probably not. The TPS setting on the different carb may cause a code, but you should have seen that by now.
1983MonteLS
25
4
How long should I expect to see this flashing? I’ve turned it off and on /started and each time has been flashing with no following code
1983MonteLS
25
4
It will flash each code 3 times before moving on to the next. If you are only getting the code 12, with the key on but engine off, then it is nothing to worry about.
It’s flashing upon starting the engine and following. - I’m sure it would flash if I just turn the key on and didn’t start but didn’t do that yet
79 USA 1
1,065
2,039
Maybe I assumed here where I should not.
You do have a code scanner plugged in the Assembly Line Diagnostic Link (ALDL) port under the dash and the code 12 is with the Key On, Engine Off correct? Or is this code 12 flashing without a code scanner installed and the engine running?
