I have a 74 chevy 350 in my 87 442, no matter what ive been trying it just seems like it doesnt run right. So im searching for ideas: the engine is; a supposably rebuilt 74 chevy 350 with about 60,000 on it, vortec heads, gm performance intake, 224/234 duration cam with .465/.488" lift, holley street avenger vaccum secondaries 570cfm carb, 160 thermostat, 17 inch plastic flex fan, a slightly larger 3 core radiator, accel plugs, wires, distributer, headman headers, and march serpentine converstion. My issues are: heats up to about 250 or slightly higher if i leave it idle for a while and the idle gets higher with the heat. I can feel the secondaries open and it pops throught the exhaust when they open. I cant get it to run worth a sh*t when its cold, and it sometimes randomly will miss and another question is, what should my idle in gear, and timing should be? right now i got it at 650 in gear when the cars running about 180ish degrees and the timing is 8 degrees advanced at 650 and im running some where around 10" of vaccum in gear idling. Any suggestions for improvment?
