patmckinneyracing said:....eventually after it gets warm ill step on the gas and hear a backfire and it goes down to 1000 rpm. the car is all stock and the carb is rebuilt. im car savvy but i've been out of the v8 seen for awhile. can anyone help?
Now I agree with it possible being the fast idle screw requiring adjusting. But at the same time, if your car is back firing that's normally an indicator that your timing needs to be adjusted. Plus if the timing hasn't been checked, being that your running a 24 year old stock set up, than you might want to just check it anyway just for safety sake. Good luck and let us know how it turns out.
ok, so by advancing or retarding the distributor it may stop the back firing? i just installed an MSD coil, MSD cap and rotor, and accel 8mm wires, and it seems that its back firing more. and i know there is no crossed wires. i triple checked before starting. one other thing, this car is completely stock (smog pump and all the hoses) i really want to gut all the smog stuff, but there's all these metal lines running into the exhaust manifolds and hoses running into the carb. what needs to be done to delete all this smog stuff? i also have been told by a mechanic that i should keep all the smog stuff on even if i run headers.. he says that cars runs like crap after you delete the smog system. whats the pros and cons of deleting it?
