Classic Tube vs Inline Tube
6,013
12,729
I'm looking to replace the fuel and brake lines on my Regal. It looks like the two biggest vendors of pre bent lines are classic tube and and inline tube. Anyone have experience with one or the other? Also my Buick engine has the fuel pump on the driver's side, is that going to be an issue because I know Olds and Chevy engines have the fuel pump on the opposite side.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
All the in line tube stuff I bought always needed tweaking
It was never "right"
Tuffregal83
639
1,150
Lockport, Il
Just got done installing inline tubes front power disc brake conversion kit on my buddys 1965 LeMans he was still using the 4 wheel drum w/single (suicide) master cylinder. I thought it was a great kit and we did all new lines I think the kit should of came with a new rear hose at the axle but whatever other than that was easy and nice kit
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Classic all the way, Inline can
  • Winner
Reactions: 4 users
Nov 4, 2012
6,013
12,729
I assume there is there a reason?
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Back in the days of early web design, theirs really sucked. When I clicked on the item, it didn't line up with the correct year, so I received a slightly different kit than what I thought I had ordered. Only 2 pieces were off, the m/c to prop valve. I had already installed the rest of the kit, and the individual pieces had part numbers. They wouldn't even sell me 2 correct parts, and insisted that I return the entire brake line kit. I bought a Right Stuff kit and used the other one as parts over the years.
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,697
Spring, Texas
Joe, I'll have to look the next time I'm at the storage, but I think everything I've bought was Classic Tube.
6,013
12,729
Looks like classic tube may be the way to go. I really just don't feel like fabbing lines myself again. My only concern is still that the fuel pump is on the driver's side. I don't want the lines to be plumbed to the wrong side.
melloelky
4,162
9,569
mass
just in time for the holidays,imagine the look on that special someone's face when they open their gift this year and realize how special they really are to you..
  • Clever
MrSony
6,831
6,741
Des Moines, Iowa
Get lines for a V6 regal. Or a carbureted Turbo car. All you will need to make yourself is a pump to carb line if you can't find/use either of yours. I chopped mine in half and put a regulator inline due to me needing a spacer for linkage to clear. Same with an aftermarket intake.
