Do the dash lights work? Check at night time. If so, that's not it. Only other grey I'm seeing in that area is a wire that comes from the brake light switch, and becomes a green at a connector under the steering column. The green then goes up to the multi-function switch on the column for the cruise control. It is the wire that disengages the cruise when the brake is applied, not sure why they used it for the alarm.
