gpracer4790 said:
bygddy said:
Ditch the 600 vacuum sec Carb
Ditch the performer intake (nothing more then weight savings over stock intake)
Install 750 DP
Install performer RPM intake
Set initial timing at 16*, total at 36*, all in by 3000
Long tube headers are a must.
Without rereading this I going to assume stock smogger heads. Your giving up a world right there.
That cam likes a 2500 stall.
Even with smogger heads these changes alone and shifting the thing at 5500ish should put you solidly in the low 14's high 13's with traction.
we cant get the performer rpm intake with the heads we have only choices are what we have and air gap performer its a 650 v.s. carb and timing is at 16 ,36 in by 3000 have long tube headers i have a 2800 stall might throw in it and will get head # i think your right on heads
If a performer fits an RPM will fit..... its a significant improvement. Your timing is bang on, converter will make a huge difference, , but heads are where the money is.... any or all of the smogger heads are a waste. The only ones I use are the 305ho heads (416 casting) and I spend hours porting them to get them where they need to be. There are so many decent budget offerings out there now that its a waste spending time or money on old parts. Look at a set of pro-filer's, right around $1100 shipped and dollar for dollar nothing will touch them. Heads and converter, Carb, intake puts that car in the 12's all day assuming your math is right and its a "real" 10.1
