i am running a 350 sbc, full roller... eagle rotating assembly, lt4 hot cam, edelbrock etec200 heads, magnum chromoly push rods, 1.6 roller rockers, vette springs, performer rpm intake, and i have tried a q-jet, holley 750 dp, and my buddies street demon 750, car ran the best with the street demon... 200-4R trans and 373 rear... and i would be amazed if i am even knocking on 13's door... pretty sure she can run in the 14's all day, but at the ebd of the day, its a SBC 350 towing a heavey *ss gbody... without nos or turbos, she aint going much faster... sure there is probably a ton more i could do, and spend ridiculous money doing it, but i am fine with 14's... for now...[/quote}
Hey BPTTONE, from what I see, the LT4 Hot Cam is the only thing in your set up that stands out as the wrong part. Specifically are you using hydraulic rollers or solid? That cam needs a 11:1 or better to get real power but, the cam is optimized only for a FI set up.
The LT4 hot cam is ground to be drivable under the control of the OBD2 system. Without FI, It's hurting you bad. You should be in to the mid to low 13s if the cam was right. If you have Hydraulic lifters change to solid. It would change the cam's profile slightly higher and it would pull up to about 7000 and better.
T
