Re: Convert digital to analog odometer?
I can get the PCM to learn the IP Theft-Lock code, you turn the key on and the THEFT light blinks for 10 minutes. After that she starts right up. If you disconnect the IP cluster while car is running, the PCM interprets it as a broken wire and will allow the car to start normally even with the IP missing altogether. I think if I can get a replacement bulb for the LCD I can get the '99 odo working again. No bulb is listed because the friggin' FACTORY MANUAL still has the analog odo featured in '99, I guess they didn't get the memo.
EDIT: This is a common problem, and the bulbs are not available. I may have to McGiver something.
