Coolant temperature sending unit for gauge package. Need one with 3/8" npt threads
gnvair
1,102
1,305
I swapped over to after market heads that use 3/8" npt threads rather than the 1/2" npt that my stock heads had. Does anyone know the part number of a sending unit with 3/8 npt threads that would be compatible with the stock coolant temperature gauge? I really want to keep the sending unit in the head and not move it it. Thanks!
pagrunt
9,167
15,346
Elderton, Pa
2134793 for the current AC Delco unit, TS76 for Standard Motor Products. Search any '80 up A/G with a Chevy engine & you'll be good.
79 USA 1
1,065
2,039
Cheektowaga, New York
200kss
20
Missouri
I had bad luck with an aftermarket one of those. Had a brand new one read incorrectly and go to 225 degrees before then thermostat even opened. Swapped in a used original and its back to normal. Anyone used the new AC Delco version?
gnvair
1,102
1,305
I'm sitting here testing resistance on the different coolant temperature sending units. I have found that the GM specified part# is 8993146/D1885 for the 80-up cars with the gauge package. I have found that at 70 degrees that the resistance shows 3,160 ohms.
By comparison, the original 1/2" thread GM sender from my 78 shows about 800 ohms at the same temperature. I have another identical GM sender that shows the same (about 800 ohms).
I tested another new GM sending unit with 3/8" thread part# 25037346 and it shows about the same as the first 3/8" thread sensor mentioned above. It makes me wonder if GM did something different on the 80-up gauges to coincide with the different resistance ranges of the gauges. The issue I am having is that with the aftermarket TS76 sending unit the gauge barely moves off the cold mark. It worked perfectly before swapping the cylinder heads (and smaller sending unit).
  • Informative
