Nah, it’s in the tune. I have nitrous envy - I need one of those BAD.I wanna see the spicy air that bends the Fancy Boi rods.
Aside from the spring, what are you using for bewst control?
Did the smallest spring with the boost controller net 9-11psi? Or without the boost controller?
Well that makes sense. I read your post twice and couldn't tell if you were using it or not. Then I pulled up the pic that you linked (post 208 IIRC). If that's a VS gate, then I just added springs to one of them yesterday in a friend's car. He made 4.5-5 psi on the small diameter spring. We added the largest diameter spring to get to 10. If yours is the same gate, then you must have a well designed hot side. I put in that same spring on my awful hotside and make 11 haha. And that's after changing mine up a bunch over the winter (I used to make 18 on that spring).
My experience with the meth is that you're hurting your power production until you get to 7-10 psi. If you have it on at 4psi, then it hasn't been helping. Are you running 50/50 water/meth or washer fluid that's more like 35% methanol?
I'm liking that you're creeping up on it. You're onto this, especially if you get in 8-10 runs with some good data. I'll guess that your boost controller works great.
I think it's worth it.I'll tweak the car as time allows, but like I said the number it could get and the number I am seeking could be many hours of tuning apart... and just not worth the effort.
