Ahhhhh, I missed your text between the pics. It makes more sense now but, it seems as though you ran your rails in parallel versus the series recommended in the manual? Or, am I looking at it wrong?
Exactly how mine is setup. A little more plumbing, but a more efficient system.LOL - it was just a feed/return issue in the regulator not a fuel leak. I just had to reroute a couple of lines.
It goes from a -10 AN main feed to a Y-block which splits into -6 AN to the rails (back feed), the rails then empty (from the front) via -6 AN into the regulator, and there is a -6 AN return to the tank. Pretty straight forward.
Is that a speed density system or MAF? I've always found that SD changes its tune with the season.
Prerequisite idle clip? I dont see it?
