I bought some e-bay rails and had tabs tig'd onto them to mount on the Trailblazer intake. I had to cut down the mounting bosses as well. My rails are custom fit to my intake so if I swap intakes for whatever reason, then I'm going to need to adjust the intake to fit the rails - not a bog deal really, unless I sell the car to some unsuspecting person (I wouldn't do that though.)
I went with rails from ebay only because of the inside diameter being 5/8. I called Holley and looked everywhere for them. It seemed most were 3/8 inside diameter and only the custom rails I found were 1/2". And Holley does make a set for a Trailblazer intake that would accommodate the 210's with fuel hats. And I feel your pain with alignment - I test fitted them about 20 times to get them to align correctly. IIRC the Trailbazer mounts are not symmetrical side to side. I know my rails are side specific. I've got photos somewhere - I thought I put them in my thread, but they aren't there. Maybe I IG'd them, dunno.
As you've discovered, all O-rings aren't the same size :
Fuel Injector Components, O-rings, Seals, Filters, Caps
<style>#html-body [data-pb-style=HE00RLN]{justify-content:flex-start;display:flex;flex-direction:column;background-position:left top;background-size:cover;background-repeat:no-repeat;background-attachment:scroll}</style><div data-content-type="row" data-appearance="contained"...www.fiveomotorsport.com
But I contacted my injector guy and he sends them to me for free. He's in Buffalo - you can find him on Facebook - Grant J Farmer Fuel Injector Services.
Not sure how I missed this post. Thanks for the info and insight. Yes, it is been a long trip down Struggle Street with Satan Elmo holding a lit match telling me to "vaxx" my kids and take them to story time with drag queens along the way... or else.
I found this crappy bit of data on the box fresh Deka 80s.
For reference here are the rails I am running:
Summit Racing SUM-227152 Summit Racing™ Fuel Rail Kits | Summit Racing
Free Shipping - Summit Racing™ Fuel Rail Kits with qualifying orders of $109. Shop Fuel Rails at Summit Racing.
No o-ring data provided.
Similiar units from Holley:
Holley Sniper 850013 Holley Sniper EFI Fuel Rails | Summit Racing
Free Shipping - Holley Sniper EFI Fuel Rails with qualifying orders of $109. Shop Fuel Rails at Summit Racing.
Unsurprisingly, no data either.
So the only thing to do is measure the bung, add the appropriate amount of squish, and ordering the right ID/OD o-rings. Something that is rarely disclosed or discussed.
On the mounts... here are the iterations I have been through at this stage. On the left are the supplied units from Summit which worked right up until they didn't, complete with extra holes added by me. They pushed the rails away from the lower manifold bungs and attempt to stand them upright at the same time, while suspending the injectors with too much vertical play. The aluminum ones on the right fixed the vertical play and brought the injectors into better alignment fore and aft. But, still not enough to mix the misalignment. The third iteration are the ones in the middle. These key-looking brackets allow the injectors and rails to sit in their natural and intended position. Nothing is forced on any axis. It's been a process to say the least.
Unfortunately these remain untested as I had to drop everything yesterday afternoon to rescue Natasha who'd locked herself out of the Camaro at the school. Turn about is fair play considering she dragged this heap home the other night. Might be time for a remote keyless entry option for her car through her phone... or mine?
Final point before I go grab a bite.
I have a glycerin filled gauge coming for tomorrow (https://www.amazon.ca/gp/product/B07T68T29H/?tag=rippca-20), remembered that the TBSS has a pressure transducer available (just need to swap the adapters between vehicles), and I decided to get some 2.125" tall polyurethane bump stops (https://www.amazon.ca/gp/product/B000CNB5OK/?tag=rippca-20) to replace the foam ones. This should alleviate the suspension droop/fender-liner smashy-smashy problem for the time being.
More to follow.
