Crate 350 swap
I don't think the picture is an actual representation. The description says "long block" not "complete engine".
I don't see any accessories here:
Also included in the turnkey packages are:
* Holley carburetor with electric choke
* Chrome air cleaner assembly
* ACDelco spark plugs
* HEI distributor
* Chevrolet Performance Parts red spiral core spark plug wires
* Long water pump
* 8 in. harmonic balancer
* 12 3/4 in. flexplate for automatic transmission
* Oil filter and adapter
* PCV valve
* PCV hose
* Oil dipstick and tube
* Fuel pump
* Starter
Ok I guess you can tell this is my first rodeo
I talked to the guys at summit and I was lead to believe that’s how it came I guess I misunderstood them , thanks for the clarification.
Reactions: 83MonteCarloSS
Ok just to correct this for future views, this does come with the accessories. The water pump is counter clockwise so a new fan & fan clutch will need to be purchased as well, I’m still looking into the a/c.
You can just buy a standard rotation water pump and use all of your accessories and fan set up then sell the reverse rotation pump.
The reverse pump needs to be used with a serpentine set up.
Reactions: 64nailhead
Reactions: 08Malibu
