Cutlass supreme Accident
mickeypowa
146
38
Tahiti - French Polynesia
Hi guys!
Do you know if this part can be replaced? This is the part where the front panel bolt on.
Because when I close the hood, we can see that it has been bend 2 inches back maybe
What do you recommend ? Try to bend forward or replace if its posible ?
Thanks
Bitterman
230
190
Yes, that is the core support. I think a few vendors sell used ones. Check out the for sale section. Someone on the forum may have one for sale.
1,167
2,638
West Virginia
Do you have access to saws and welders?
Doug Chahoy
2,565
2,663
Once all the sheetmetal is out of the way, look for any buckles in the frame.
mickeypowa
146
38
Hi guys !!
I have a few questions :
1- I would like to put a 4 rows champion radiator. It has 1.50 inch entrance and exit whereas my actual radiator has 1.75inch exit. Do you think I have to change the rubber tube also or will it be ok??
2- my old trans cooler is connected with 5/8 inch tubes. After my trans will be cooled by the champion radiator. But I see only holes in it. What do I need to screw in theses holes to be able to plug my tubes ? A connector ? Do you have a link where I can buy it ?
3- my fan was pulled out of the fan clutch during the accident because the radiator hit the fan. I was able to put the fan back on the clutch. But the cover doesnt want to be put back in place. What can I do ? Should I buy a new fan ? Do you have a link or reference. ( I dont want to go to electric fan)
Thanks a lot
Mickey
