Yes, direct bolt in, just the balance issue.The 403 and 307 use the same crank?????
First order, some might be left overs from Iowa buts still good. 😉what we need here is lots of popcorn....![]()
Oh My... I wouldn't use the block or the crank. Curious to see how this pans out.20 on the crank 20 on the rods
40 on the pistons
this thing was beat to poop
No all the 307 cranks should be the same. A 350 N crank is a good option if you want stronger but only marginally heavier. Also the 74 to 80 350 crank is the same and would require less weight to balance.
