Thanks. I believe it was $52 through summit.
thanks for reminding me we get hosed when it comes to prices in Ontario....
You can use the factory disc/drum proportioning valve but you would need an adjustable valve in the rear line.
I have Wilwood rear disc on my Monte and a Wilwood adjustable proportioning valve knob style mounted to the frame just before the rear tire and the stock valve up front, what I like about this set up is you can adjust the lockup on the rears something you can't do on a factory style disc/disc valve. On my car with front runners I rely on the sticky rear tires to help stop me so I need the adjustability
The angles and mounting holes look correct but now ya got me wondering about the lines coming up a little short.The only possible problem I see changing out your stock disc/drum proportioning valve for the disc/disc one is if your stainless lines are already in place and if your replacement valve is not an exact physical match your current lines could end up being too short.or wrong angles etc.
I don't know what the actual residual pressure is in the rear but when I bought my rear disc set up for my Moser 9" probably 15 years ago Wilwood recommended this set up with this proportioning valve over any other changes, they said it will reduce line pressure over 50%.wouldn't that still allow the 10 lbs of residual pressure to reach the rear disks?
Well, I just replaced the entire brake system on my project Regal and I bought a new brass proportioning valve that was a stock replacement it physically bolts in and the brake light switch mounts correctly but if I was going to use original lines the rear one would have been probably an inch too short but it did not matter to me since I was making all new lines out of cunifer tubing. I am not sure if there would have been any other issues with the rest of the lines but locations and angles looked about the same but stainless is not very forgiving.The angles and mounting holes look correct but now ya got me wondering about the lines coming up a little short.
If the rear line does come up an inch or so short i think i might be able to squeeze an extra jnch out of it. There seemed to be a little bit "extra" length around the bend near the crossmember.Well, I just replaced the entire brake system on my project Regal and I bought a new brass proportioning valve that was a stock replacement it physically bolts in and the brake light switch mounts correctly but if I was going to use original lines the rear one would have been probably an inch too short but it did not matter to me since I was making all new lines out of cunifer tubing. I am not sure if there would have been any other issues with the rest of the lines but locations and angles looked about the same but stainless is not very forgiving.
I do know that where the adjustment is now if my foot is not on the brake pedal the rear pads are retracted enough to were there is hardly any resistance changing them out.
Wilwood told me once I dialed in the setting they said I would be impressed with how well balanced it would stop and I am impressed.
Anytime I give someone a ride they always crap their pants thinking there is no way I can stop in that short a distance after going so fast.
The car proves them wrong everytime.
