olds307 and 403 said:The HEI is a great distributor. That being said, you need the mechanical advance curve to come in quickly. Hopefully the Moroso weights allow this before 3000 rpm, the stock weights do not. You do need a stop screw as shown to limit the mechanical advance, grind as necessary to achieve your maximum advance. They all add extra timing in higher rpms. Just be careful when tapping the hole to keep the shavings out of the magnetic pick up. I went with the Mallory breakerless. I can set my base anywhere and with the lightest springs, all in just over 1500 rpm! I would try the lightest springs and see where your advance comes in with your dial back light. Give it a quick high rev, you will probably see an extra 3-5 degrees.
Sounds like at least someone else has actually done this correctly before, I agree, I do it a little different than you by using light springs to set the max total timing, then wire it closed to figure out the total advance curve. I have done my own stop screw on one of the junk Advance Auto dist. before when I first fired it there was almost 48 degrees mechanical advance in it. Doing that takes a while but can be done on the car with a dial type light. And I would love to ride with you guys in your cars when you can make the cap lift up on the spring hold downs, and spin on its own. Maybe you should use a magneto if your subjecting your car to retina detaching G-forces
