Ok i finally got ahold of some timing tape..
I backed off the initial timing down to 18. My dist advance is coming in at 1500 RPM and all there by 3000 RPM. I'm getting 14-16 degrees from the dist advance, i cant be any more precise because my timing light kinda sucks.
So my total timing is 32-34 degrees right now.
I pulled plugs again and it's showing signs of running lean.
When i put the car in gear it's still dropping from 1100RPM down to a 600-700 fluctuation in gear.
Took it for a drive..
If i accelerate hard from a dead stop and hold it in 1st letting the engine spin up to about 4000 RPM then letting off the throttle, it pops through the exhaust like a machine gun.
From a cruise in 3rd gear giving it hard acceleration but not enough to down shift, it acts sluggish and doesn't want to rev up.
What confuses me though, if from a dead stop i put it in 1st and give it WOT it just rolls the back tires until i let off. How can it pull so good in 1st and just fall on its face in 3rd?
I have to note, when pulled back in after the test drive i brang the car to a stop and kept in gear, it would fluctuate between 600 and 500.
I put a longer line on my vacuum gauge, when i put the car in gear and the RPMs drop to 600/700 the vacuum signal drops to about 6" of vacuum.
I also tried ported source of vacuum, the car stalled as soon as i put it in gear, that shouldn't happen.
What do yall think now? I'd have to agree at this point i think my problems are in my carb.
