DoubleV said:Not really IMO. I've seen Qjets run incredible on engines much wilder than yours. It just boils down to tuning and that's where a Holley shines. They're easier to tune and you can buy them already setup for 'racier' engines. With the Qjet, the starting point is usually much further away from where you want to be.
Just curious but have you tried the tip in preceedure with the APT as shown in Cliff's book?
Glad to hear, i'm not giving up on this Qjet, i know the potential it has. No i haven't messed with the APT at all, the ONLY adjustments I've made to the carb thus far are simply idle mixture. I can't find my book on Qjets from cliff, can you run through the procedure for me?
On idle mixture, if i hit the point where the mixture becomes too rich the vacuum/RPMs should drop right? i make adjustments in 1/4 turn at a time observing both gauges.
Beyond that i think i'm going to need different jets. I'm still really in the dark with tuning Qjets so i appreciate the help guys.
Before i make any more adjustments i'm going to swap the donor carb on and see how it acts, hopefully the donor carbs not too small and runs lean too , that would be my luck lol.
