if thats the case, im pretty sure my 307's number one was to the right of the wire connections. cant say for sure tho, that was awhile ago...
Usually, the added length is to allow for the proper wire clips to be used to keep the wires neatly tucked away. If you find you have a lot of length left, its usually because the original wiring clips are gone or out of place or the routing has been abandoned. Id much rather have a wire a bit too long, than not long enough.cutlassguy said:ive gotta call BS on that...ive bought more than one set of wires where they give you kooky lenghts and no matter what, some are longer than they should be. bosch is the worst for than...
Yeah...and remember that the distributor position can make all the diff when routing the wires too.cutlassguy said:same here bill. altho i did have a set once that had one wire that was too short for anything. im not sure if someone screwed up somewhere along the line or what, but this one was a good 2 inches short for my #8...
