Divine Hot Rod Intervention?
I'll just drop the crossmember on his head
Drop a crossmember, it's your "fault" even if an accident. But make him do it to himself by bolting upright, that's both enjoyable and not your fault.
Double pleasure if in recoil hits the head on the ground falling backwards and tries sitting upright again out of reflex.
Reactions: fleming442
He went home. I'm not religious, but something definitely happened when the speedo bullet retention bolt got tight then loose. This NEVER HAPPENS!!!!
Here's one for the bolt on guys. The beefier AutoGear tailshaft housing requires cutting into the crossmember.
Don’t stop now
Yup. It's in now. All downhill from here? No f-ing way!!!
And, Jimmy's son, Zach, is "helping"
Drunk *ss passed out, snoring. I'm friends with the girl he's banging's mom, and she said he grinds his teeth. I guess I better not teabag him.
Should of dropped some bolts on his nuts, good chance he would of shot his head right in the frame or rocker. He might of been hurting but we all know we all would of been laughing cause we're guys & that would of been some funny :poop:.
I think I should be good. I swapped out the drag radials for the street tires last night. Tonight should just be putting the tail shaft housing on, adjusting the shifter, installing the trans, driveshaft, exhaust, and bleed the clutch. Then, put the console back in.
Hope it all went well
