CUTLASS Does anyone have a wiring diagram for the air conditioning compressor wide open throttle cut off switch used on the 83-84 Hurst Olds and the 85-87 442
What's the center to center width on the terminals?
I realize now it might be the same connector as the 10si or 12si alternator plug. The width is about right. Item A in the group might do the trick. This is the book with the GM hardware
Reactions: Sweet_Johnny
What I was planning to do was add the cut out switch into one of the compressor leads and break the connection at wide open throttle. This would be on my 78 Malibu.
Looks like I need to track down the accelerator pedal rod support plate. The part number is 25517909 in the Buick and Chevrolet GM catalogs so it shouldn't be too difficult to find.
But I did learn the Oldsmobile engineers really went over the top with the compressor circuit compared to the other divisions.
Hi there. I’m digging around trying to understand the new ac delco compressor I was recommended. Seems like my buddy whom is installing it in my 79 coupe classic has trepidation as the compressor needs a sensor wiring in order to run it properly.
As the ac delco is a remanufacture and the original set up may need wire love.. that said can you give me your thoughts on this. So I may pass it over to him as he is a bit perplexed as he cannot figure it out as of yet. Thanks Dez
