Door hinge roller bearing replacement/rebuild
kustomkyle
646
47
Has anyone had their door go clunk-clunk-clunk when opening? Both of my doors are doing it. I just replaced the upper hinge on the drivers door with a nice tight one off of a 4-door Malibu (which I found out has a smaller spring) thinking it would cure all issues the old (hogged-out hinge pin hole) one had. As soon as the spring was reinstalled and tension was put back on the bearing during installation, it started to squeak and clunk just as, if not worse than, the worn out original had.
Are there any replacement bearings available out there? I have seen the Dorman/"Help!" ones at Auto Zone, but they look different (I think they are for GM trucks). If not, are they rebuildable somehow? I soaked the one on the current hinge in 5W-30 synthetic motor oil for a week before I installed it, but it takes about a whole can of WD-40 to make it somewhat tolerable now. Any ideas?
12,175
9,793
The bushings and pins are available from your local GM dealer. I guess the Dormans help parts should be adequate enough. Just bring an old bushing and pin along with you so you can match them up.
Oz71
12
North Florida
X2
The doorman pin & bushing kit is what I used to replace both sides about 3 months ago.. Works great and were like $5 a piece... Very easy to install...
20,397
I think they come with oversize bushings as well in case the pin has worn past the bushing
kustomkyle
646
47
Are you guys referring to the hinge pins and bronze bushings? I mean the roller bearing that the hinge arm rides on, the one with the 3 round divets in it; it keeps the door from opening to far/stay open when opened. If it is a GM part, what is the part#?
20,397
don't blame me, I was following longroof's lead... :mrgreen:
found this on another site...
It's staked in so you'll need to grind or chisel away the top of the pin then it knocks out downwards.
The replacements I've seen (Motormite/Dorman) are pretty horrible quality; they also don't fit right. You have to open up the large (lower) hole with a die grinder and keep trying until the new part fits. It secures with an E-clip at the top so no worry about having to stake it in.
Dorman/Motormite # 38433
Balkamp (NAPA) # BK 6755165
Disco Automotive # 2168PK (though I don't think I could buy "Disco" brand!)
or you can one from a dealer
