I remove my driver's door to service the hinges. The lower hinge bushings were slightly loose. The uppers were quite loose. My theory - prove me wrong: since the weight of the door is pulling on the top hinge and pushing on the bottom hinge shouldn't the bushing wear be the same on the upper and lower? The force on the hinges is, lets say 100 lbs pulling on the upper and 100 lbs(negative) pushing on the lower. The only item I can see is the door detent spring putting a great deal of pressure on the top hinge bushings accelerating wear.
Would a lower pressure spring cause less wear on the hinge and yet still offer detent resistance?
Do I win pizza dinner or am I out to lunch?
