So I fixed the striker bolt on my Cutlass on friday night. It was plated over and the adjustable nut was tack welded and wouldnt adjust blah blah blah. So I fix it right and put the striker back in and close the door. Well the damn thing wont open now...
Pull the handle, you hear the mechanism move on the latch and nothing happens. So I wrestle with it for about an hour and wind up banging all the tabs flat on the slider nut inside so I can unscrew it from the striker. So I open it and get the door open and take the latch mechanism out.
Looking at the latch mechanism it appears as if the mechanism that opens the release for the latch has broken off and isnt allowing it to release open so its basically stuck closed.
Has anyone ever had this happen? It seems like an odd thing to break.
O and follow up question. Are all g body door latches the same?
