Picked up some Re-Man (DuraLast) Blazer Front Brake Callipers from AutoZone for my Blazer Brake Upgrade.
Seem to be experiencing some drag (especially on the Left ) Drivers side brake caliper.
Has anyone else run into such similar issues with Re-Man calipers for these cars?
As recommended by several brake experts I spoke with, I've plumbed in a 2lb residual pressure valve to the front lines....perhaps this is the culprit?
I also installed a Tallon HydroBoost brake set up at the same time. Wondering if the adjustment for brake engagement needs to be adjusted at the brake pedal?
