An adapter bushing may be necessary. You might be able to use an A or B body upper hose for an Olds 307, 350 or 403 but their rads are 2" to 3" wider. If you stay 307, nearly any rad will do. The SBO Olds 260 and 307 are extremely easy to cool, the 350 OK, 403 not very nice, Olds increased each SBO by enlarging the bore only. The baby Olds V8's very thick cylinder walls and 8 to 1 compression with small ci help a bunch. I have a 1/2 plugged rad in my 88 with the 215 absolute max, usually around 190 with the 260, it was 230+ in a short trip with the 9.6 to 1 Olds 350.Niether Auto City or Cold Case radiators have the inlet and outlet correct size for Oldsmobile 307 application. Theirs are for Chevy. My inlet is 1.25 and oulet 1.5". I would need a upper hose with a 1.5" to make the one from Auto City to work.
Any hose suggestions? Other than flex.
