I just messaged them. Haven't heard back yet. I usually get quicker responses here! If I add a thick washer it all tightens up. Not sure how great of an idea that is!what did Western Chassis say about the problem when you contacted them?....![]()
^^This.^^Are the inner and outer bearing cones tight against the spindle diameter?
Most drop spindles are for S10's & might use the different wheel bearings. I had the same issue w/the drop spindles I put on a 78 Malibu. Verify the wheel bearings fit properly on the spindle itself. If so, you'll have to get the correct S10 rotor (they are different).
Calipers & pads will still work.
