Longroof79 said:Steve,
What's the advantage of using Camaro spindles? Acceptance of larger rotors?
drogg1 said:Jack,Steve can correct me if I'm wrong but I believe the advantage of the Camaro spindles is similar to the B-body spindles in that they are taller to improve camber gain and yes, I think they also can accept larger rotors.
=======================================================================================================pontiacgp said:Longroof79 said:Steve,
the rotors on the camaro are 11". The camaro uses the same calipers and pad that the B body uses with their 12" rotor. It's a toss up whether you gain braking with have more leverage with the 12" rotor or you lose braking with more rotating mass with the 12" rotor. We ran the camaro spindle on the race car then going with a ford 9" with 5x5 bolt pattern we went with the B body since they also came with 5 x5 bolt pattern. The lap times did not change with the different front brake set up and the driver didn't find any difference between the two.
yes drogg1 your right....the other thing with the tall spindles your upper control arm is above the horizontalline, I also have lowering springs and a tall lower ball joint which means the upper never crosses the horizontal line. That way the inside tire on a turn will push the top of the tire out giving it positive camber so more of the tire is planted on the road, while the outside the suspension is being compressed to increase the negative camber due to the arc of the upper control arm which plants more of the tire onto the road.
