So I'll probably be thrown to the lions for this, but I plan on keeping drum brakes in the rear for my Regal. I do plan on upgrading the front discs to something better. The main reason I want to keep the drums is because I want air ride someday, and most of the rear disc brake set ups require the rear shocks to be moved inward, and I'm not sure if the air bags will be compatible with the relocated shock mounts. If anyone has any info on a possible drum brake upgrade or if air ride will be fine with the relocated shock mounts, I would really appreciate it. Thanks in advance, and happy Friday.
