First I will say I know enough about electronics to get me in trouble and not much more.
A capacitor is used when there is quick spike in current draw. It acts like a low resistence battery, so it can react quicker to demand. As a side benefit they also smooth out the voltage (steadier).
I use a 38k MF 16vdc capacitor on the power side of my Crane Ignition (ever read thier instructions) just for those reasons.
A capacitor does store energy but not enough to power your system. The power in a capacitor still comes from your battery/alternator , it can't create power.
I think you would be better served getting a good alternator (not PEP Boys) that charges at low rpm. I use one from SVA that puts out a 100 amps at IDLE, 160a peak.He makes bigger ones that could power a city block!!!
A high output alternator costs and weighs less then more batteries if that matters to you.
Hook this to the isolator, run 2 of the biggest batteries that will fit.Oh, the batteries must match, ie same brand , type and age.My choice is Orbital 6 from NAPA , it is thier AGM type battery.
A capacitor is still not a bad idea, but now you can run smaller ones, maybe on the bass amp only?
Proper size wiring and good connection will go a long way also. Don't forget Noalox on all your connections.
