(1979 MC, LG4 305, dualjet w/hot air choke, carb rebuilt by me 12/17 with new choke housing/coil, new primary pull off, deleted secondary pull off.)
So this carb has been doing great since I brought it back to life with one exception: choke and pull off adjustment. I've gotten it squared away twice now, and each time after a few weeks or months it'll come down with a hard start condition. It will turn over & fire but immediately stalls out; no amount of throttle pumping or feathering will keep it going.
Both times, my Pink Panther-style diagnostics revealed a choke butterfly that wasn't opening at all after the engine fires up & creates vacuum, leading me to put a MityVac on the pull off & find that the diaphragm has ruptured. Well, let me back up. That's what happened the FIRST time. Second time, after a few weeks with new pull off #2, the shenanigans started again this morning. I suspected the same thing & pulled the air cleaner housing. Sure enough, butterfly was staying 100% closed. I dicked around with things a minute & spun the choke around until it would stay open & running when cranked, then I accidentally tapped the adjustment screw on the pull off and it dropped like the hammer on a pistol. POP! I re-set the choke butterfly to closed, cranked the engine over, and the pull off wouldn't open the butterfly. Same no-start condition. MityVac now says pull off #2 is ruptured.
Spidey sense is telling me something could be sticking, or bent, or misaligned? Pics attached for reference. I did lube the fast idle cam a bit with WD40 but it didn't help. Maybe its just crappy aftermarket parts? Any clues what it might be, given my description? Would I be better off just converting to a manual choke? I'm about ready to.
