megaladon6 said:i wouldn't wire it to the starter. that's way too easy to bypass, one long screwdriver to short the terminals and done. you're better off hooking it into the ignition coil power circuit.
Or snip a length of wire with the correct end on it from the junkyard, then tape the wire into the loom to make it look original 🙂shotgun said:Used a piece of thick black vacuum line with "correct" ends glued on.
If you can get easy access to the starter... with headers the only reasonable way to get to mine is to crawl under the car, which is lowered, so you better have something long that won't make contact with a ground anywhere. Also, if they already have an extra HEI +12v plug (or even a regular spade plug, that's all it is) with a good length of wire, all they'd have to do is plug it into the distributor...megaladon6 said:i wouldn't wire it to the starter. that's way too easy to bypass, one long screwdriver to short the terminals and done. you're better off hooking it into the ignition coil power circuit.
82355supreme said:If you have an electric fuel pump, simply take the fuse out & carry it with you. You did install a fuse in an electrical circuit, right?
I don't know if thieves carry spare fuses with them, but this is one more way to hamper their efforts.
