Ebay Q-Jet, should I?
a lot of people roll with 1970's chevy 350 carbs and disregard the computer system. You don't have to buy a numbers matching Q-Jet if you just need it to run.
Yeah. I could also have tossed on a 50 buck two abrrel from the junkyard and my old two barrel intake if I wanted it to just run. I've tried chevy qjets, Pontiac and olds qjets on my car. All restored/rebuilt to factory specs by me. All ran like sh*t although the olds was the closest. Chevy was the worst. Qjets are application specific. My '78 Buick 17058241 has ran the best even in piss poor original shape. I plan to rebuild that one soon.
I had no idea - never knew that. I thought getting rid of the computer would make it run easier. What model number is your Q-Jet. I have a few laying around. 2 or 3 are brand new (rebuilt). All are from different year Olds.
To be clear, my car has a 1976 Buick 350 shoehorned into it. Not stock at all. .030 over, comp 268H cam, .469/.469 218/218 duration @.050 lift. Mild headwork/three angle valve job. The carb number is 17058241. '77-79 Buick and '78-'79 Pontiac, with changes to the insides like idle air tubes and jets and whatnot to the pontiac being as it is a Buick carb originally. Quadrajets are very versatile while at the same time being very picky with what engine they are on. Yes, you can take a chevy qjet and make it run fantastic on a Buick, but for the amount of work and time you'll spend it's not worth it. I bought my carb for 60 bucks on ebay and it works, it just needs a rebuild. Well plugs epoxied, maybe jetted up a size or two and different secondary metering rods. Plus ethanol resistant accelerator pump and gaskets because I live in the land of corn.
I saw it sold- you got it? Good. Yeah, it's dirty all right, but that can be fixed. Just give it a good EXTERNAL cleaning and try it out. It may run great. If not, then you can open it and learn all about Q-jets. After all, you have us here to help. What could go wrong?????
Dirt can be a good sign for a Qjet. It may mean it is factory original and not hacked up and ruined by a carb remanufacturer. A reman sticker on a Qjet is a red flag.
Getting rid of the ecm doesn't make things easier, it opens a can of worms.
Sadly they do more than just that. They do odd things like plugging up air bleeds and installing generic spec parts. Some even drill passageways larger than stock.
wow - I was thinking worst case senario they would just be lazy and clean out the small tubes with like 24K gold testing acid. I didn't know they hacked them up that bad. yikes
Yeah, it's original alright. It runs fine enough as it is. I probably will never divulge into major rebuilding such as replacing throttle shaft bushings, idle air tubes and whatnot, but a basic re gasketing, cleaning, and new parts like jets rods brass float ethanol resistant stuff and expoxying the well plugs and whatnot. If a carb I get is bad enough I'll just send it off and have it rebuilt if its a numbers matching carb or more often than not I'll just buy one. Cost the same plus or minus core charge.
That's for sh*t sure. A stock carb has been methodically tested and optimized for that specific application by engineers with zillion dollar equipment at their disposal. . When you have the original equipment carb you just clean it- that's all. It can take a few motor modifications in stride and still operate well. It's when you get crazy that you need to start re-jetting and stuff, and that is usually not by much. Now consider a computer carb that is operating on commands from the ECM that has been programmed for all possible operating conditions. To replace that type carb the best you can do is find the model carb that came on the last non-computer version of your motor and hope for the best. Taking a totally different model and trying to adapt it can be so frustrating that you want to just grab an off-the-shelf-mail-order-whatever and be done with it. But you never are, because it will never be right. That is why Mr.Sony did the right thing. He found the correct model carb for his motor and will optimize it to work with the motor he built. THAT is the way to go.
Reactions: MrSony
