Yes....in order for the engine to move the weight of the car without bogging down, there has to be a gearing up of the torque the motor makes. Thats why when referring to diff ratios, the higher the number, the lower the gearing....meaning the more motor revs needed per single rev of the axleshaft...ReQ said:...... it will take 2.52 revolutions of the input shaft to equal 1 full turn of the output correct?
then it gets divided again at the rearend by 2.73, and 2.52x2.73=6.87, so this means it will take 6.87 turns of the engine to move the wheels one full revolution? this seems wrong to me but who knows.. its all voodoo to me right now
but all of that aside, how do i figure out what my actual final drive is including tires?
In your situation, maybe the real issue is what size tire is best for the situation....if you never change gears, you are basically running the engine, the trans and the diff at the same ratio all the time all the way around the track, and the only variables are the engine rpms and the tire diameters. For example, if you are pulling away from every one out of the turns, but they catch you and pass you at the end of the straight, then maybe your gear is too low or your tire is too small.....Im not sure what problem youre trying to solve .... just throwing out scenerios.
